340 to Electronic Ignition today
Posted by a_lead on January 26, 2008 at 12:32:33 from (69.137.41.169):
Removed the breaker ignition today and installed the Pertronix Electronic ignition along with a new Pertronix coil. The new coil is larger in diameter than the old, should have ordered a new bracket; will order next week.
Went in real easy following the instructions that it came with. Also opened the plug gaps to .040".
Don"t have a real load to put behind it to test, but it does seem to have more ommpf than before. Have a steep grade in the drive that I was able to climb in 5th with T/A back. Don"t think that I could have done that before the change.
Edward
