I doubt if you hurt the system. The pump rund the distributor, and it was probaably not completely dry in the pump housing. I would not put alcohol in the Hytran. The rubber and other components would not like it at all. It would also probable loosen a bunch of sedentary sediment and cause it to plague the system with dirt. Heat with a portable heater and some protection is probably the solution of choice. Removing a few gallons into a pan, then heating to drive off the moisture would help also. Many stories in the archives on ridding oil of H2O. Getting it all out when changing is tough. Good luck, JimN
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
