Re: Cub transrear noise- need help
Posted by Kristof on January 27, 2008 at 08:09:03 from (87.64.206.27):
In Reply to: Cub transrear noise- need help posted by robertb on January 27, 2008 at 08:02:01:
Did you check if there"s still enough oil in there?
Best way to check it to drain the oil, remove the cover and just check everything. It could be a broken or worn out bearing, damaged or worn out gear... But when open you could also check the shifting mechanisme, maybe you"ll find your problem there.
Hope I could be of any help,
Kristof
