Re: Cub transrear noise- need help
Posted by Janicholson on January 27, 2008 at 09:12:21 from (66.173.50.109):
In Reply to: Cub transrear noise- need help posted by robertb on January 27, 2008 at 08:02:01:
They are noisy whiny and loud. If you have just gotten it, and it is a whine not a growling grind, I would ignore it as it is likely normal. They range from a noticeable whine to pretty obnoxious. And run for ever. If it makes raspy grinding noises or the noise is changing as time goes on, I would say a bearing rebuild and possible gears are needed. The forum will help, but a service manual is mandatory. JimN
