ok new info on the A,it is a super i'm pretty sure 99%.the tractor has had a plate welded on top of gauge/ignition panel it is the flat panel not oval.rod was made to operate hydraulics.next serial number plate has been plated over several times so i look at original style for a super a and the 1450 number i gave is were rpms should be.so i gave wrong number cant see serial number.now on the engine block the machined smooth surface at top right side below head is the number 304531 is that the same as serial number under seat?thanks.
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our
... [Read Article]
