Re: Drove the B I hauled in yesterday
Posted by Janicholson on January 27, 2008 at 16:16:35 from (66.173.50.48):
In Reply to: Drove the B I hauled in yesterday posted by old on January 27, 2008 at 16:07:47:
Glad it is going!!
There is a choke cable affair that runs to the mechanism you discussed. The choke cable operates the mag ground. If it is not a show queen to be, go with a replacement choke cable, and make up the clips needed to keep it as straight as possible, and tidy. Original cables might be hard to find, but I have not looked. Another way to do it is to use a wire from the terminal and a grounding switch at the operator's platform area to shut it off. JimN
