Re: MCV cover poppet and spring question
Posted by Owen Aaland on January 27, 2008 at 21:36:34 from (207.13.114.48):
In Reply to: MCV cover poppet and spring question posted by pt 756 on January 27, 2008 at 11:00:32:
The purpose of the sump check valve is to allow the steering hand pump to draw oil through it to prime the system if the MCV pump should fail and the steering system loose it's prime. If the sump check valve should fail then you will loose the MCV hydraulic system.
If you want to remove the plug you can push it out from the back side. The hole just goes through the housing to the reservoir.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
