Posted by Bob Kerr on January 27, 2008 at 23:53:16 from (205.188.116.73):
In Reply to: Farmall M No Power! posted by david123 on January 27, 2008 at 19:53:59:
Does it sputter when you let the clutch out? If so it may need another turn on the main fuel screw on the carb. If it backfires out the intake then it is too lean, if black smoke in the exhaust, then too rich. Also try reving it up to high speed and then pull the choke hard for a second. Sometimes that will knock a piece of dirt loose plugging something up in the carb and get them going. You might give it a compression test also and post the results.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
