Re: 806 Steering, Brakes, and T/A
Posted by Janicholson on January 28, 2008 at 06:59:53 from (199.17.6.122):
In Reply to: 806 Steering, Brakes, and T/A posted by mhalter on January 27, 2008 at 19:09:06:
If the Tractor Vet were here (I wish)
He might say Well I havent got my gauges on it so I can only guess.
The pump supplying pressure to the TA also pressurizes the Steering/brakes.
If the pupm pressure is low it will happen. If the MCA is sticking it can happen. If the brakes are bleeding of pressure from an internal hemorage it can happen. If it has been coming on slowly, it is more likely a pump issue. if it started all at once, it is likely a Oring, or seal, or strainer, or MCA. JimN
