806 Steering, Brakes, and T/A
Posted by mhalter on January 27, 2008 at 19:09:06 from (4.225.82.233):
Our 806 has some steering, brakes, and T/A trouble. Here are the symptoms.
1. The most often occuring and most noticable thing is when you put it in gear and let out on the clutch, it has a hit and miss chance of whether it will move or not. Sometimes it starts to move right away, just as it should. Other times you let out on the clutch and nothing happens. When it does this, if you push back in on the clutch and wait, you can see, feel, and hear a "clunk" and you know the tractor is ready to go then. After the clunk, you let out the clutch and it functions as it should.
2. When working the tractor and coming to an end, if you begin to turn push the brake to aid in the turn, sometimes it will stop moving, resulting in a scenario similar to symptom 1.
3. When it gets cold, or when its warm and you park on slightly unlevel ground, when changing the hydraulic filter, or just sometimes out the blue it will have no steering, T/A, brakes or be able to move upon starting (sometimes it will move but loose ability to move within a few seconds, push in on the clutch, wait, and it will move for a few more seconds, and so on). PTO and hydraulic outlets function properly during this time.
4. T/A function is delayed sometimes. Sometimes you can drop the planter in the ground and go to push the T/A lever forward and it will hesitate then lung. The same applys for pulling back on the T/A. And sometimes it works normally.
So what do you think the problem may be? MCV pump? Any help would be appreciated.
