With magneto ignition the magneto "kill" wiring is completely independent of the rest of the electrical system.
Instead there's simply a wire running from the mag's shorting terminal to one terminal of the ignition switch; the other ign switch terminal then connects to ground.
However if you've swapped the magneto for a coil and distributor, connect the hot side of the ignition switch to the ammeter post that's connected to the light switch fuse holder.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in
... [Read Article]
Latest Ad:
[More Ads]
