Re: H running bad and spitting gas from carb bottom
Posted by Bob Kerr on January 28, 2008 at 21:11:46 from (205.188.116.73):
In Reply to: H running bad and spitting gas from carb bottom posted by Scott Rukke on January 28, 2008 at 12:27:47:
I will "third" the water in the dist cap and or stuck intake valve posts. squirt some kero or pb blaster or somekind of oil in the carb intake (take hose off) when it is running, it might come loose, but check for water first. If it sat at one time for a long while sometimes a valve spring will get weak on a valve that was held open when it was shut off before parking it so that may be something to check later down the road.
