The firing order is 1-5-3-6-2-4 if you want to check for plug wire pranksters. Could be kids, neighbors, your brother-in-law, or your coffee shop buddies.
They have this moisture removing spray you can get in a can that may help if there is moisture in the dist. You can check the dist. seal to see if it is ok.
I don't know if this will work, but you might try pulling one plug wire at a time while it is running to see if you can isolate which cylinder is the problem if there is a stuck valve. Then you could squirt some oil in the spark plug hole to lube it. For that matter it might not hurt to pull and check all the plugs and squirt some oil in all the cylinders.
I don't know if a blown intake manifold gasket would do the same thing or not.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
