Posted by scott rukke on January 29, 2008 at 21:17:42 from (67.183.230.71):
In Reply to: farmall h manifold posted by farmerphil1 on January 29, 2008 at 19:14:26:
Cast is difficult but not impossible to weld. Problem is the contraction of the weld material after it cools. It tends to create cracks. There are several newer rods that are made specifically for cast that help with the cracking issue. They are expensive. Last time I priced them I had to buy at least 3# and it was about $60 for the rod. Whether it's weldable would depend on how it's broke and where. I have welded engines and manifolds using cast rod. I have also brazed them. In fact my distillate manifold on my F-20 had 2 cracked flanges and I brazed them. After grinding and painting you can't tell it was ever damaged. Find a good welder and let them take a look at it. In the attached picture both the left and right flange were broken clean off. After beveling all the joints to get full penetration I clamped the pieces back on and brazed them with a bronze rod and flux using oxy-acetylene. Then I ground it back to its original shape and re-drilled the holes.
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
