Re: H shifter questions
Posted by Bob M on January 30, 2008 at 06:45:51 from (151.190.254.108):
In Reply to: H shifter questions posted by neblinc on January 30, 2008 at 06:06:53:
Randy - The slots in the 3 shifter rails should all be the same size. (Obviously the .875 shifts the gear(s) that were used the most on your tractor....)
You could build-up (weld) then grind the .875 slot to bring it closer to the others. However you'll need to be very careful that the built-up slot is centered with the other 2 when all the rails are re-installed. Otherwise you'll wind up with a "notchy" neutral gate.
I had a similar problem with my Super H. However I simply built-up then ground the tip of the shift lever by trial and error until I got it where it shifted smoothly. The fact the shift rail slot sizes were all slightly different didn't seem to matter.
Incidentally that's a slick digital caliper. I bought one just like it to gage/match cutter lengths I sharpen chain saw chains....it works great!
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
