Re: Pulling a Disc with a 656 Diesel
Posted by Up North Louie on January 30, 2008 at 13:20:40 from (65.73.75.68):
In Reply to: Pulling a Disc with a 656 Diesel posted by skyharborcowboy on January 30, 2008 at 07:37:59:
Yes, they represent that type of disk.
You will have to weight your disk down pretty hard if you're going to try to tear up sod. Then it's probably not the tool for the job.
I have torn up old hayfield/pasture with a spring tooth quack drag making repeated passes in all different directions. I do that because we have ungodly amounts of rock where I live. A mold board plow is pretty much an invitation to the blues. Then I go over it with a disk and seed with a Brillion cultipacker/drill combination. I guess I use the quack drag kind of like a chisel plow, just to a lesser degree of penetration.
I am told that disk plows would work up here with all the clay and rock, but I have never fooled with one and I wouldn't know.
I kind of doubt you'll get the kind of tillage you need with just a disk. Seems to me it would just roll along the top and make slits, unless you turn them to max angle and pile on a lot of weight.
Don
