There is more to discing than just hooking it up and driving up and down a field. With an offset you are tossing a lot of soil and residue one direction or the other. If you make a U turn now you are tossing soil back to the 'windrow again. You will wind up with a very uneven field. With a tandem you need to insure the front and rear sections are working together. The fronts will pull the soil in to the center . the rears take it back out. If you are not level, or have the rears set to different angle than the front, then again your field will be totally wrecked. Best method for prepping seedbed is disc, then plow, then double disc. I'd recommend you search for the RIGHT implement, not the available or cheap one. A 12 to 14 tandem, 18 inch discs is the right one for you. Be sure and take your tape measure. Discs worn down more than an inch are useless.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
