Re: Pulling a Disc with a 656 Diesel
Posted by karl f on January 30, 2008 at 18:43:11 from (172.136.189.232):
In Reply to: Re: Pulling a Disc with a 656 Diesel posted by skyharborcowboy on January 30, 2008 at 07:51:03:
price would be scrap on up, depending on condition. say for example that to put all new blades and bearings on the disk would be $1200. that would be about your max price if it has all new blades and bearings, but the frame looks worn. a good frame could add quite a bit to the price. the more worn things are, the faster the price goes lower. my dad bought a 14 ft case disk with 40 blades at 9" spacing about 10 yrs ago when we were in a bind for around $500. it had all the outside blades damaged, one of the adjusting screws was broken, and the frame showed signs of previous repairs. we got one season out of it, and a couple bearings and a few blades ended up biting the bullet. We decided to rebuild it this year. found out the blades were 2" worn! bearings and blades approached $1700. The up side to it is that it will be like a new disk once assembled, and shouldn't need much attention for a long time.
hope this helps you get an idea of what you might be getting into
karl f
