Re: leaking carb
Posted by teddy52food on January 31, 2008 at 09:52:39 from (209.237.111.169):
In Reply to: leaking carb posted by GJS on January 31, 2008 at 08:31:02:
Make sure you have a good gasket on the seat when you screw it in and get it in tight. Also take the elbow off and check the screen. If it is letting dirt through that will hold the needle valve open.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
