Posted by Andy Motteberg on January 31, 2008 at 10:13:56 from (4.143.222.50):
In Reply to: leaking carb posted by GJS on January 31, 2008 at 08:31:02:
Make sure the float pin is in tight and that your float level is adjusted correctly. The float level can be adjusted by bending the float arm with a pliers. Make sure all gaskets are good and sealing up good. Also make sure the needle is not falling out or stuck down in the carburetor. Also make sure the carburetor is very clean inside and outside and that your adjustments are set correctly.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
