Re: 656 Gauges and Idiot Lights
Posted by Allan In NE on February 02, 2008 at 05:21:15 from (148.78.243.26):
In Reply to: 656 Gauges and Idiot Lights posted by skyharborcowboy on February 01, 2008 at 19:20:42:
Nine times out of ten the tach has a bad cable.
Oil pressure lite uses a ground searching pressure switch ran thru a bulb as is the alt lite, which grounds at the alternator.
Fuel gauge is a standard ground=full circuit.
However, you will have to replace the complete gauge head if the temp gauge doesn't work because the temp gauge/sender are all one unit.
Allan
