Re: 656 Gauges and Idiot Lights
Posted by Jerry Gilliam on February 02, 2008 at 07:57:46 from (65.4.218.121):
In Reply to: Re: 656 Gauges and Idiot Lights posted by Allan In NE on February 02, 2008 at 05:21:15:
he is telling you right. The whole cluster will have to be changed if it is the temp or fuel. The cluster was used on several models and had a dummy light for oil and charge. And actual real live gauges for temp and fuel. According to some you can't replace the temp cable as it was mecury or something like that.
However, with all your gauges out, I would look at each one individually to see. If the cabels have been cut, then that isn't good. The cluster comes with a new sending unit for temp., but usually only has the prongs in rear to plug up fuel wires. Only light sockets as well. I'm also fixing up a 656 Gas/ 263/ 1966
Good luck
Jerry
