Re: Wiring problem
Posted by James Williams on February 02, 2008 at 14:34:22 from (170.215.129.166):
In Reply to: Wiring problem posted by Tom Windsor on February 02, 2008 at 10:06:26:
Tom,It should run,but this is not reconmended,if one cable is pulled a ground,or positive runs wild and could fry somthing.I seen this happen on a boat and all of the wiring hardness was fried instanctly
jimmy
