IH 340 utility hydraulic question
Posted by tooltime on February 02, 2008 at 15:50:12 from (66.103.165.40):
was wondering if hydraulic valve assembly is still available for a 340 international utility tractor. my 340 has a transmission driven hydraulic pump, with a valve assembly housing mounted under front dash / steering housing and has 2 pipes running back to a small block wich 2 hoses connect to 3 point cylinder. also is there any way to bypass the 2 pipes wich run from front valve housing to rear block with a more modern hose / quick connect assembly?/thanks,Jim
