Re: 2656-hydraulics question-draft control housing
Posted by skyharborcowboy on February 03, 2008 at 02:19:02 from (75.211.56.41):
In Reply to: 2656-hydraulics question-draft control housing posted by bc on February 02, 2008 at 21:22:39:
I had similar problems with my power steering on my 656 and had leaking seals on my draft and lift control levers. I was told to remove the pipe in the left front under that plate to lower the fluid level in that cavity and then to over fill the fluid level by 5 gallons in the event that the seal in the clutch housing might be sucking air and causing the pump to cavitate. What I did was remove that Bull Plug that you referred to as all I could see that it was was a drain plug there was nothing behind it and over filled the fluid. The leaking has stopped, the cavitation has stopped and the power steering now works. I dont know if will fix your situation but it is worth trying.
Joe
PS. Can you turn your steering wheel while your engine isnt running? Mine would just spin with absolutely no resistance whatsoever until I did what I said up above.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
