Posted by Janicholson on February 03, 2008 at 06:21:39 from (66.173.50.53):
In Reply to: Compression check posted by junky old Farmalls on February 03, 2008 at 05:20:13:
Assuming that the throttle was open, and the starter was spinning the engine with all spark plugs out for the tests, A dual fuel C will be between 90 and 110 psi a gasoline only will be more than 120 to 145. Putting a tablespoon or so of oil should raise it less than 5#. if more it may need rings. 10% variation is more than expected, and low cylinders may have compression leaks. Gasket/valve/piston rings/piston. Good luck, keep us informed, JimN
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
