rr bearing cage
Posted by Ploughboy on February 03, 2008 at 16:39:52 from (75.183.117.89):
Trying to remove the bearing cage for the bull shaft from the differential.This started because of an oil leak on the right brake drum and band. I could not get the seal out so I thought I would remove the plate that turns out to be a bearing carrier. In the process I broke the flange. Now I need parts and some help with getting this thing off the tractor.
