Re: rr bearing cage
Posted by CNKS on February 03, 2008 at 17:17:31 from (216.144.104.128):
In Reply to: rr bearing cage posted by Ploughboy on February 03, 2008 at 16:39:52:
You have to remove the trans/diff cover. The cage bolts on from the inside. The seal comes out with difficulty, but it was designed to be removed without removing the cage. You are not the first to break one. Mike at Steel Wheel Ranch should have a good one for not much money. 785-548-7437.
