Posted by glennster on February 03, 2008 at 17:40:38 from (68.60.242.156):
In Reply to: super h knock posted by 460anger on February 03, 2008 at 17:01:55:
may have either spun a rod or main bearing. if its pulls down, sounds like a bearing somewhere. at this point, i wouldnt run it till i found the problem. drop the oil pan and check the rod bearings, then drop the mains and check em. if it ate a bearing, your gonna need to split it and have the crank cut. very first thing i would do is drain the oil filter housing into a container and look for metal shavings. there should be a littlepipe plug at the filter base, unscrew this plug drain a little oil at a time and give it a good looking over. i like to spill a little on a sheet of paper and smear it around looking for metal fileings.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
