Posted by r4etired on February 03, 2008 at 18:07:13 from (166.145.206.140):
In Reply to: Super M brake rebuild posted by Jaden on February 03, 2008 at 13:33:05:
If your disc's are bad I recommend you take them to a good brake shop and have them relinned, All disc's you buy today are aftermarket including those from CIH,The materials in them are so hard they will glaze up and be worthless,
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
