Re: super h knock
Posted by Bob M on February 04, 2008 at 07:03:58 from (151.190.254.108):
In Reply to: Re: super h knock posted by D Slater on February 03, 2008 at 20:14:05:
Bad cam gear indeed! I've had a couple cam gears let go and cause knocking just as described.
If the Super H is a Stage 2 (it has live hydraulics...) try loading the hydraulic system with the engine idling. If there's a noticeable change in the knocking sound - or if it disappears - when the hyd pump is loaded it's highly likely the cam gear hub has broken.
