Re: Re: Re: Re: Re: Re: Re: Re: 400 6v or 12v?
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by IHank on February 28, 2000 at 20:04:23 from (167.142.24.96):
In Reply to: Re: Re: Re: Re: Re: Re: Re: 400 6v or 12v? posted by Jon on February 28, 2000 at 19:41:23:
Jon- Take a look at the wire harness on your tractor. I might be that a bunch of extra wires are folded back and taped over in the original harness. If so it is a mixed blessing because the insulation is likely rotten, but you might get lucky.
Lights and bulbs are a matter of how much $$$ authentic do you want to go for.
My cynicism involves the technical point that a "12 volt starter" has down sized wires, insulation, and overall design. If you got an original 6 volt unit, never, ever, let it get re-wound for 12 volts!
Those 12 volt DC generators are still available at old car swap meets and out in the sticks car junkyards.
Do your best and good luck!
Post A Followup
: Re: Re: Re: Re: Re: Re: Re: Re: Re: 400 6v or 12v?
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
