Re: set the timming on A
Posted by gene bender on February 05, 2008 at 04:40:41 from (67.55.226.214):
In Reply to: set the timming on A posted by farmer john on February 04, 2008 at 15:26:41:
Remove all plugs so you can turn it over easy. Now when the piston is coming up to TDC remove the cap and look to see if the rotor is pointing at the post on the cap going to #1 plug. I am assuming that you have a mag.The rotor will point to the tower and when you hit TDC it will snap.Sometimes when the points are changed they get the rotor out of time so ir doesent line up on the tower of the cap makes for hard starting. I have 7 A,BN and B with mags cant beat them for starting.
