No, they are not the same. Strangely enough, the H's PTO shield is a few inches LONGER!
For the PTO to work without chattering too much on corners, the tip of the PTO shaft and the hole in the drawbar need to be a certain distance apart. Also, the hole in the drawbar needs to be a certain distance from the axle so the implement doesn't hit the tractor's tires. An H's rear end housing is smaller, so to make that all happen, the PTO shaft sticks out of the back of the tractor more than on an M.
If you use an M's PTO shield, it won't cover the whole shaft on an H.
Today's Featured Article - Field Modifications (Sins of the Farmer) - by Staff. Picture a new Chevrolet driving down the street without it's grill, right fender and trunk lid. Imagine a crude hole made in the hood to accommodate a new taller air cleaner, the fender wells cut away to make way for larger tires, and half of a sliding glass door used to replace the windshield. Top that off with an old set of '36 Ford headlight shells bolted to the hood. Pretty unlikely for a car... but for a tractor, this is pretty normal. It seems that more often than not they a
... [Read Article]
Latest Ad:
[More Ads]
