Re: Farmall 460 overheating Fast!!!!
Posted by El Toro on February 05, 2008 at 19:02:39 from (205.188.116.73):
In Reply to: Farmall 460 overheating Fast!!!! posted by Redsm on February 05, 2008 at 17:27:08:
If the belt is tight your pump may be the problem.
Touch the bottom hose and see if it's cooler when the temp is up. It may be the impeller. When the engine is cold look in radiator when the engine is at an idle and see if the coolant is moving. Hal
