Re: Super-A main bearing
Posted by Janicholson on February 06, 2008 at 07:53:31 from (199.17.6.122):
In Reply to: Super-A main bearing posted by P and R Pete on February 06, 2008 at 06:32:28:
STD stands for standard. This means it is either the original, or the bearings were replaced without turning the crank, or the crank was replaced with standard sized journals.
I would say the pitting was from old oil not changed enough. It looks pretty good to me, having done its job. Polishing the crank if it is scored, might just let new standard inserts be used again. Good luck. JimN
