Re: Super-A main bearing
Posted by El Toro on February 06, 2008 at 07:55:54 from (64.12.116.73):
In Reply to: Super-A main bearing posted by P and R Pete on February 06, 2008 at 06:32:28:
That could be the original since it's a standard
size bearing meaning the journal was never ground undersize. When I did an A the journals looked
like bronze or copper, but the shaft only needed to be polished and I had to use .002" undersize bearings. I bought them from the auto machine shop. The shaft looked very good for all the sludge I found in the pan and over the pickup screen on the oil pump. I would have that block cleaned if any of that bearing metal went through the engine. Hal
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
