Re: Two Questions:F-14 clutch,650 LPG
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Skip on February 29, 2000 at 04:33:18 from (209.34.22.196):
In Reply to: Two Questions:F-14 clutch,650 LPG posted by RED Blooded on February 28, 2000 at 15:59:26:
Wardiner, I forgot to mention you should open the "vapor" valve to start then after warm up, open "liquid" valve and close "vapor". Very important to keep both valves cloed when you shut it off.
Good Luck
Post A Followup
: Re: Re: Two Questions:F-14 clutch,650 LPG
