Posted by Bob M on February 07, 2008 at 05:06:13 from (151.190.254.108):
In Reply to: Wiring on Super M posted by Ryan J on February 06, 2008 at 19:06:35:
Ryan - Presuming your wiring is correct and the plugs are not fouled there's two things I would check:
1 - Ignition timing. If the distributor's very much out of time the engine can pop and fire but won't run. Static timing for the Super M should be 0 deg (= TDC).
2 - Coil. If you used a so-called "12 volt" (internally ballasted) coil AND a series ballast resistor, the combination will cause current thru the coil to be too low to give good fire at the plugs. Simply eliminate the series resistor and you'll get a nice, hot spark.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
