Re: Update on water in oil on M
Posted by El Toro on February 07, 2008 at 15:31:50 from (205.188.116.73):
In Reply to: Update on water in oil on M posted by 1 Dollar on February 07, 2008 at 12:29:59:
You may have a hole in one of your sleeves. You should've pulled the pan and looked for any antifreeze drops on the sleeves. Losing the rust inhibitor in the antifreeze may have cause that if
you find a sleeve wet. I would have that head magn-fluxed for a crack if there's no leakage from the sleeves. I had this problem on a GM car. Hal
