Re: farmall A clutch
Posted by gene bender on February 07, 2008 at 21:58:00 from (67.55.226.214):
In Reply to: farmall A clutch posted by farmie40 on February 07, 2008 at 15:37:00:
You dont have the wrong flywheel. Check the yoke the clutch throwout bearing is on. Its probably bent and thats why the clutch wont work. Isnt the clutch and pressure plate the same as you took out and you are sure the clutch plate isnt in backwards
