Re: Pictures of inside of engine (antifreeze issue)
Posted by Janicholson on February 08, 2008 at 13:35:59 from (199.17.6.122):
In Reply to: Pictures of inside of engine (antifreeze issue) posted by 1 Dollar on February 08, 2008 at 13:18:24:
Old is right. It will be necessary to pull the sleeve to see what is going on. It probably could be repaired with a repair (thick) sleeve then rebored to fit the thin standard sleeve. JimN (I assume because I forgot, that this is a dry sleeve engine. If it is an A B C type wet sleeve, it is the sleeve seal O ring, JimN
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
