Re: Pictures of inside of engine (antifreeze issue)
Posted by r4etired on February 08, 2008 at 15:09:44 from (166.153.110.94):
In Reply to: Pictures of inside of engine (antifreeze issue) posted by 1 Dollar on February 08, 2008 at 13:18:24:
Remember when these tractors were in their prime anti freeze for most farmers was cost prohibitive. Most were drained every nite and refilled the next day,this caused a lot of scale buildup in the block and heads, Also caused hot spots,especially on the sleeves,Eventually it caused the sleeves to crack, some didn't show up for years,others show up when the new antifreezes are used as they contain corrosion and rust inhibitors.Freeze cracks I have found will generally lock up the piston. My 2cents worth.
