Re: Belt Pulley Drive Rebuild
Posted by Haas on February 08, 2008 at 18:31:34 from (12.65.54.190):
In Reply to: Belt Pulley Drive Rebuild posted by Bud W on February 08, 2008 at 07:22:05:
If the flange does not have grooves to accomodate the O rings, I would not install them, as this will affect the gear setting as well as put more strain on the flange retainer bolts. The O ring is designed to seal while still allowing the flange to bolt up solid to the mating surface. The O ring can only do this if it is in a properly designed groove. My parts CD shows two versions of the belt pulley assembly. One has the O ring, the other does not. the one with the O ring shows a steel pulley, so I expect it is the later version.
