Posted by gene bender on February 08, 2008 at 20:32:50 from (67.55.226.214):
In Reply to: Switch posted by Tom Windsor on February 08, 2008 at 19:27:47:
Yes the sw does need to be grounded. I use an OHM meter to check go to ground cable to sw to check.You do have a wire running from the field on the gen to the sw dont you for hi-charge. By the way TOM the TEA is under snow now and cant wait until spring getting awful thirsty for some as a dummy forgot to dry some last fall.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
