Farmall H Clutch Rattle
Posted by John Warner on February 08, 2008 at 20:42:01 from (24.56.230.242):
I have a Farmall H. When I got the tractor the clutch would not engage. I replaced the Clutch Release Sleeve Carrier. Now the clutch seems to work, but when you engage the clutch there is a bad rattle noise and you can see the clutch linkage viberating. When you disengage the clutch the rattle and viberation stops. Has anyone seen or know of what to check that may be causing this problem?
