Posted by r4etired on February 09, 2008 at 04:34:13 from (166.145.212.157):
In Reply to: Farmall H Clutch Rattle posted by John Warner on February 08, 2008 at 20:42:01:
Some times because of lack of lubrication the pipe part of the support will wear out allowing the through out bearing to flop around. Grab a hold of the grease pipe and wiggle it front to back that will tell the bad component.When that fitting is greased it lubes the slide,there is a small hole in the bearing race to allow a small amount of lubricant into the bearing.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
