Posted by Janicholson on February 09, 2008 at 06:09:37 from (66.173.50.86):
In Reply to: Switch posted by Tom Windsor on February 08, 2008 at 19:27:47:
John M below is correct Tom, all the switches that control the generator are four position switches. Low High Dim Bright if your switch has only three positions it is definitely a lights only switch and cannot be used for the control of a cutout equipped generator. The tractor can be used if you ground the field terminal with a jumper, and leave the lights on. This will provide a modest charge to the battery while you get the correct switch with two resistors on the back. The light switch you have cannot have any terminal grounded. Good luck, JimN
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
