Posted by karl f on February 09, 2008 at 06:14:56 from (172.163.9.188):
In Reply to: Switch posted by Tom Windsor on February 08, 2008 at 19:27:47:
WAIT we're talking about a farmall A/c/H/M right? 3 position light switch is NOT a charge switching switch! you need a 4 position,but one from an 06 or newer will NOT work.
the positions of the switch will be L H B D. there will be 2 resistors on the back of the switch. I don't know if this switch is available new.
i bet the one you have has only one resistor. and when in the first most counterclockwise position, there is no continuity bewteen the power in and any of the other terminals.
if you cannont find the right switch you may have to use the 3 position for lights only, and install a genny mounted regulator. it will look very close to original, and original for a slightly newer machine. hope this helps.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
