You say with the choke wide open, thats the way they should run. I'll take a guess here and figure you mean you have to have it choked all the way for it to run and if so it means you have a fuel flow problem. I would start by pulling the carb drain plug out and make sure you have a good steady flow of gas out of it for 5 plus minutes. Catch the gas so you can save it and also look at it to see if you have water in it. If you don't have a good flow there work back till you find where you loose the flow. If it flows good at the line but not the carb then you probably need to rebuild the carb
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
